Ubiquiti POE Injector, 24VDC, 24W
Ubiquity
Ubiquiti POE Injector, 24VDC, 24W, Gigabit Ethernet, ESD protection & LED, Surge and Clamping Protection,Maximum Surge Discharge
$33.00 Inc Tax
Ubiquiti POE Injector, 24VDC, 12W, Gigabit Ethernet, ESD protection & LED
SKU:POE-24-24W-G-WH
Tech Specs: Click Here
Description: Ubiquiti PoE Adapters provide a variety of features to help protect your PoE devices.
Electrostatic discharge (ESD) is the leading cause for outdoor device failures. You can effectively protect against ESD damage using a grounded Ubiquiti PoE Adapter, TOUGHCableTM, and TOUGHCable Connectors
Features:
•Surge protection
• Clamping protection
•Maximum surge discharge
• Peak pulse current
• AC cable with earth ground
• Output voltage: 24V DC @ 1.0A
• Rated voltage: 100-240V AC @ 50/60Hz
• Input current: 0.6A @ 120V AC, 0.4A @ 240V AC
• Inrush current: <60A peak @ 120V AC, <120A peak @ 230V AC
• Surge protection: Difference and common mode
• Clamping protection: 11V data, 60V power
• Max. surge discharge: 1500A (8/20 μs) power
• Peak pulse current: 36A (10/1000 μs) data
