Ubiquiti U6+,Dual-band WiFi 6 PoE Access Point
Ubiquity
Ubiquiti U6+,Dual-band WiFi 6 PoE Access Point, 2x2 Mimo, 2.4GHz @ 573.5Mbps & 5GHz @ 2.4Gbps,300+ Devices*No POE Injector*Upgrade UAP-AC-LITE
$242.00  Inc Tax
Ubiquiti UniFi Wi-Fi 6 Plus, Entry-level access points for small venues. SKU: U6+ Description: A compact access point improving upon the U6 Lite by bringing higher performance and dual-band WiFi6 support. Ideal for small and medium-sized businesses. Tech Specs: Click Here Installation Guide: Click Here Features: • WiFi6 (2x2 MIMO) • Powered using PoE •140 m² (1,500 ft²) coverag •300+ connected devices •**No POE Injector Included**
  • Availability: Pre-Order
  • Model: U6+
  • SKU: U6+
  • Brand: Ubiquity
