Ubiquiti UniFi Protect Network Video Recorder - 7x 3.5" HD Bays - Unifi Protect Pre Installed - NHU-RPS Compatible
Ubiquity
$1,321.38  Inc Tax
Network Video Recorder Pro
The Network Video Recorder Pro (UNVR Pro) is a business-grade network video recorder that provides data redundancy and long-term storage capabilities.
UNVR Pro
The UNVR Pro is a UniFi OS Console that runs the pre-installed UniFi Protect application and has a 7-drive hard disk drive (HDD) bay that offers the greatest storage capacity of any UniFi OS Console. The powerful, easy-to-use UNVR Pro can be deployed in minutes and support systems with up to 60 cameras. Combining the best features of Cloud and onsite surveillance systems, UniFi Protect gives you centralized, local, low-latency access to all of your live camera feeds and recordings, as well as remote access from anywhere in the world via unifi.ui.com and the Protect mobile app.
UNVR Pro
Features:
The UNVR Pro also offers expanded RAID configuration options for enhanced data protection, applying either RAID 1, 5, or 10 based on the number of HDDs installed. It's also equipped with a 1.3" touchscreen display for concise, convenient video event previewing.*
  • (7) 2.5"/3.5" HDD bays
  • (1) 10G SFP+ port
  • (1) GbE RJ45 port
  • 2U-sized, rack-mountable console (kit Included)
  • 1.3" touchscreen with video event previewing*
  • Pre-installed UniFi Protect application
  • Simple, Bluetooth-powered setup via the UniFi Protect mobile app
  • Automated RAID 1, 5, or 10 HDD configuration
  • Connect a SmartPower Redundant Power System to create an uninterruptible network
Note: Please ensure your HDDs meet Ubiquiti's general guidelines and aren't included in their list of incompatible models.
*Will be included in a future console update
Optimize your camera security
The UNVR Pro is designed to support the most demanding, multi-camera systems.
Immense Storage Capacity
Install up to seven multi-terabyte HDDs (2.5 or 3.5")
Fast Fiber Connectivity
Create high-speed connections to your Protect cameras and UniFi devices
Plug & Play Design
Run UniFi Protect instantly after setup
Instant Data Protection
Protect your drive data with automatic HDD configurations
Reliable Backup Power
Keep your UNVR Pro running through power failure
Ample HD and 4K video storage
Access high-resolution recordings when you need them.
Camera
Camera
Reclaim your power
Stay operational through sudden power failure by connecting to the USP RPS* or Switch Mission Critical*
* Sold separately
See how long you can store your footage
Storage duration will vary based on camera count and preferred image quality. Use the tool below to approximate yours.
Low Quality
Normal Quality
Best Quality
Camera
More ways to monitor what matters most
Instantly view live feeds, access recordings, and manage your cameras with UniFi Protect.
iPad
iPhone
Specifications
Mechanical
Dimensions
442 x 325 x 87 mm
Weight
Without Rackmount Brackets: 9.2 kg
With Rackmount Brackets: 9.45 kg
Enclosure Material
SGCC Steel
Mount Materials
SGCC Steel
Hardware
Max. Power Consumption
160W
Max. Power Budget for Drives
135W
Power Method
(1) Universal AC input, 100-240VAC, 3A Max, 50/60 Hz
(1) USP-RPS DC input, 11.5VDC, 13.91A
Power Supply
AC/DC, Internal, 200W
Networking Interfaces
(1) 10/100/1000 Mbps RJ45 Ethernet
(1) 1/10 Gbps SFP+ Ethernet
RF Interface
(1) Bluetooth v4.1
LCM Display
(1) 1.3" Touchscreen
Bootup Animation: Bootup in Progress
Firmware Upgrade Icon: Firmware Upgrading
Steady White: Factory Defaults, Awaiting Adoption
Steady Blue: Device is Adopted
Management Interface
Ethernet In-Band Management
ESD/EMP Protection
Air: ± 12kV, Contact: ± 8kV
Operating Temperature
-5 to 40° C
Operating Humidity
5 - 95% Noncondensing
Certifications
FCC, CE, IC
LEDs
Ethernet
White: 10/100/1000 Mbps
SFP+
White: 1/10 Gbps
HDD
Amber: Disk Error, White: Disk Detected
RPS
Blue: Ready
  • Availability: Pre-Order
  • Model: NHU-UNVR-PRO
  • SKU: NHU-UNVR-PRO
  • Brand: Ubiquity
